You can implement a user level data cap by NxFilter and NetFlow.
You can set up a user level data caps in NxFilter by utilizing NetFlow data from a router. NxFilter can associate NetFlow data to a user login IP address and if there is a user used up data over the limit you set on a policy, NxFilter blocks all the DNS requests from the user.
To enable data caps, you need to have a router or firewall that supports NetFlow or IPFIX in your network. You also need to configure it to send NetFlow data to NxFilter. And then run NxFilter's built-in NetFlow collector on System > Setup > NetFlow. After that, you can set data cap on a policy.
There are several rules for NxFilter to import NetFlow data.
* NxFilter supports NetFlow v5, v9 and IPFIX.
- One of the source or destination IP address of a NetFlow data must be associated to an IP address of a logged-in user on NxFilter.
- NxFilter ignores internal traffic. And one of the source or destination IP address needs to be a public IP address.
- NxFilter keeps only TCP/UDP data.
