DHCP Reservation Problem
  • DHCP Reservation Problem
    Hi Team,
    I'm currently having a problem with the DHCP Reservation, I tried to reserved a sample IP address and Mac address using multiple devices to troubleshoot but the devices are not getting the ip address that I'm assigning. In addition to this, when Im trying to delete the reservation im getting this error "DhcpReservedDao.delete, No such data!".
    But I'm seeing the records under the DHCP -> Reserved IP and I cant delete my reservations and that's where I found out that the reservation is not working.
    I tried to uninstall my whole installation and install a fresh copy of nxfilter but the problem still persist.
  • OK. We will look into the problem.
    • We found a bug about the deleting problem. Howver, DHCP Reservation works fine in our test. Try the attached one. There's nxd.jar file in the zip file and you can replace /nxfilter/nxd.jar with this one.
      • Thank you! I'll try it later today.
